Facing issue building a simple RAG application using RetrievalQA
Hi all, Here is a simple RAG app code, I am facing issue running it. Issue probably lies in the HuggingFaceEndpoint’s repo_id used. Could you please guide me what repo_id should be used here? Also, how to identify when to use which repo_id?
Here is the code:
from langchain_community.document_loaders import TextLoader
from langchain.text_splitter import RecursiveCharacterTextSplitter
from langchain_huggingface import HuggingFaceEmbeddings, HuggingFaceEndpoint
from langchain_community.vectorstores import FAISS
from langchain.chains import RetrievalQA
from dotenv import load_dotenv
load_dotenv()
# Loading a text file
loader = TextLoader("./Dummy_docs/Test_doc_1.txt")
documents = loader.load()
# Splitting the text into manageable chunks
splitter = RecursiveCharacterTextSplitter(chunk_size=500, chunk_overlap=50)
chunks = splitter.split_documents(documents)
# Converting document chunks into embeddings and store in FAISS
embedding_model = HuggingFaceEmbeddings()
vectorstore = FAISS.from_documents(chunks, embedding_model)
# Creating a retriever from the vectorstore
retriever = vectorstore.as_retriever()
# Initializing the LLM endpoint
llm = HuggingFaceEndpoint(
repo_id="tiiuae/falcon-7b-instruct",
provider="auto"
# Create the RetrievalQA chain
qa_chain = RetrievalQA.from_chain_type(llm=llm, retriever=retriever)
# Define your user query
query = "Can I cancel my e-ticket booked online from Busways, at the counter?"
print(f"\nQuery: {query}\n")
# Get the answer
answer = qa_chain.run(query)
print("Answer:")
print(answer)
I am a beginner in GenAI. Than you for your support.
The format of repo_id is correct, but since the model has not been deployed, it cannot be used as an API. Refer to the following post to find a model that can be used. Using a local model is more reliable, but requires a GPU.
Got yu! I went ahead to check the supporting inference points, and it worked using this:
repo_id=“HuggingFaceH4/zephyr-7b-beta”
Thanks again!
